302 WaterPump
Old Mar 26, 2003 | 12:20 AM
frozen bronco's Avatar
frozen bronco
302 WaterPump
Will a Ford Racing Maximum Flow Aluminum water pump (PNE6MS-08501C50-M) for a 1986-1993 Mustang fit a <a href="http://motorhaven.autoanything.com/">302 </a>for a Bronco.
Thanks guys I know someone here can help me, you've never let me down in the past.
Old Mar 26, 2003 | 12:23 AM
roush17996's Avatar
roush17996
302 WaterPump
if the bronco has v-belts-it is the wrong rotation, but otherwise if the length is the same, should work
Old Mar 26, 2003 | 01:31 AM
frozen bronco
302 WaterPump
Thanks roush17996 the description provided states:
Premium reverse rotation serpentine belt aluminum water pump. Heavy duty shaft and bearing with stamped impeller. Provides good flow and pressure for engines that operate below 6000 RPM. Will fit 1979-1985 with minor modifications.
I thinking that it's the correct part, you just can't be too sure when your ordering parts over the internet. You can't just take them back so I try to make sure that I have the correct part before ordering.
