Weather stripping destroying doors (pics)
#31
jc8825 i feel them same way theirisno need for the rear opening doors, i had two older fords that were ext cab for my mud trucks/ driver truck and i never had a problemwith them or need the doors to open. my super duty just givesme a headace! doors squeak, paint is rubbing off, plus like you said have you ever seen one hit in the side they fold up like tin foil!
#33
my 04 did this under warranty and the dealer wanted to paint the entire doors but i said no. the reason they rub is because ext cabs don't have a fixed pillar in the middle of the cab and ever pot hole bump or divot in the road or any flex in the frame suspension makes the cab flex side to side making the doors rub back and forth causing the rubber to rub the paint off the doors. Go look at ANY regular cab or crew cab super duty truck? OK did you look and what did you see? no rust, no paint missing right its because the cab doesn't flex making the doors rub against everything. I LOVE my truck but i will NEVER buy another ext cab as long as i live!
#34
really guys? i stop and talk to every SD owner i see at gas stations and such and i have never seen a reg cab or crew cab truck have peeling paint like my ext cab does? even my dads 2000 crew cab diesel doors look brand new on the seal side, no rubbing, rust or squeaks. now that im thinking of it my buddies 2002 crew cab doesnt do it either, nor does my uncles 99 f-250 work truck. And the 99 is beat to death!
#36
#37
I had this issue and figured it out. Was looking around to see what was in there to be making the rubber seal abrasive and if you don't wash your truck enough all the dust and dirt lays in there. I took a piece of 2000 grit sand paper and run it over the rubber seal until my arm was ready to fall off.... If you think rubber can't be polished think again LOL. After I did this I taped off the back side of the door and gave it a shot of bed liner. The rubberized liner has enough give in it that it doesn't chip like acrylic paint so those trying new things give this a try and giver hell. Oh and another point who cares what color the inside of the door is you don't see it from the outside when the door is closed
