Transmission questions
Old Jun 9, 2011 | 12:11 PM
Scheol's Avatar
Scheol
Hi, truck is an '86 F-150 4x4 351w C6. I'm going to be rebuilding the trans very soon and I have a few questions. First, I'm going to be replacing the stock torque converter with an aftermarket one and I was wondering what the trans input shaft diameter is. Also, if I go with an aftermarket TC, will I need to get a new flexplate? If so, does anybody know what the specs on the flexplate need to be? IE, number of teeth, balancing, weight, etc.
Old Jun 9, 2011 | 02:21 PM
Ken Blythen's Avatar
Ken Blythen
If you go to the 5th sticky down ( 80-86 Tech tips, Tricks & Projects) on the 80-86 forum index page, you'll find a section on flywheels, flexplates, clutches etc.
Old Jun 10, 2011 | 11:40 AM
Scheol's Avatar
Scheol
Thanks a lot, I didn't know that was there.
The one question I still have that I couldn't find an answer to was will and aftermarket 11.25" torque converter bolt up to the factory flexplate? Or do I have to get an aftermarket one?
Old Jun 11, 2011 | 01:29 AM
cj06's Avatar
cj06
if the convertor was made for a C6 then it should bolt up to your flexplate , but to be sure it would be best to ask the company that makes the convertor !
why do you need the diameter of the shaft ?
sportsman70
Nov 21, 2014 05:42 PM
Brown Falcon
17
Aug 10, 2011 04:22 PM
GreatNorthWoods
16
Apr 20, 2011 04:29 PM
linckeil
Apr 27, 2006 08:46 PM
