Can I fix my camber problem
Old Jun 9, 2011 | 12:12 AM
YoungFordAddict66's Avatar
YoungFordAddict66
Ok im tired of the passenger tire leaning with the awesome camber position my D50 is in. I dont if an alignment/tire shop can fix it but found the camber parts on rockauto and was wondering if this was something i could fix myself and if anyone has tried to do this themselves?
Old Jun 9, 2011 | 12:31 AM
pjwoolw's Avatar
pjwoolw
Not familiar with your lift. But it must have a drop bracket. If its adjustable you can use that adjustability to help with camber issues. Make sure all your spring bushings are in good shape or new before you make any alignment changes.
Old Jun 9, 2011 | 01:19 AM
YoungFordAddict66
Yes it has a drop bracket i believe and no i dont think its adjustable. It had new front shackles installed with the springs when the lift was installed. but the back ones may be worn out.
Old Jun 9, 2011 | 08:45 AM
RRranch's Avatar
RRranch
IF all of your bushings are good especially the pivot bushings, then you need to find a spring shop to correct it. DO NOT try to correct OBVIOUS camber with alignment bushings. Get a spring shop to set your arch to an eyeballed zero camber and only then let an alignment shop mess with it. First you Ned to check your ride height though. Check the same place at the fender lip on all four wheels and see if they are off. More than a half inch difference will mess things up. The problem with the ride height should become pretty obvious.
mightymoose95
Jan 6, 2014 02:30 PM
ItsAFord55
Aug 21, 2012 10:17 PM
nitrain03
Apr 5, 2012 08:12 PM
gweeds
May 29, 2008 05:30 PM
Joe Scarbrough
Jun 30, 2003 07:43 AM
