Break in period
Old Jun 8, 2011 | 08:35 PM
tolliewolly's Avatar
tolliewolly
Break in period
Is there a break in period on the 6.7 truck? Someone told me I couldn't tow for 1500 miles. I scratched my head on that one. Also when is first service?
Old Jun 8, 2011 | 08:52 PM
sandyc's Avatar
sandyc
Read your manual, it explains everything. 500 miles before towing.
Old Jun 8, 2011 | 08:54 PM
cummins cowboy's Avatar
cummins cowboy
I dunno but I got an extra 5 mph on a large grade in our area called parleys canyon, I was pulling the same trailer and last fall when the truck was new I got 75 mph at the top and the other day I did 80 over the top. don't know if winter fuel was a factor, truck has 12k miles on it now.
another thing I found was that the truck runs alittle harder with your foot a bit off the floor, it seems to slow a little if you push the pedal all the way to the floor. running 3/4 throttle seems to be the way to get the most from it.
Old Jun 8, 2011 | 09:25 PM
Biggziff's Avatar
Biggziff
500 miles before towing (to allow the ring and pinion to wear in) and 1000 miles engine break-in.
Old Jun 8, 2011 | 09:52 PM
kper05's Avatar
kper05
Attached is a document that should get you started.
The manual explains quite a bit.
File Type: pdf
Sketchz
May 26, 2017 09:18 AM
Rifle
Aug 12, 2012 03:14 PM
gmichaels
Escape & Escape Hybrid
Jan 22, 2012 07:18 PM
ponyboy123
6.4L Power Stroke Diesel
Jul 21, 2009 06:18 AM
jdsdidit
Oil & Lubrication
Jun 29, 2007 02:29 PM
