Help
Truck is in the shop again for milage issues
Ford said nothing is wrong and i must have changed my driving style
I think they are freakin morons
Most of you know my previous issues with these trucks lately
I have had my share of bad luck
But i got the tranny flash and a few weeks later i seen my milage dropping like a rock! I was getting 18.2 now i get 15.2!
Used to regen every 400 miles or so
Now it regens every 100-150
Ford said nothing is wrong that the milage a flucuate and regens can be from 100-500 miles
Am i over bitching about this? I think 15.2 is sad!
Why did it change after months?
I got 15 in Janurary when i never shut the darn truck off an it was on winter blend
I have had lots of trucks and i think i know when something is wrong
Your driving style may not have changed but the DPF could be filling a bit more if the DPF is not getting full burn-outs. I've noticed that when I'm towing a bunch, I never get a regen. When I go a few weeks without towing, the 150 mile regen cycle is pretty predictable. Are you doing any driving where you can really heat up the exhaust? I'm beginning to believe that regular city or light highway driving is not really enough to properly clean out the DPF. It's like the active regen cleans it a little, but not as much as high exhaust temps with a regen. The more you can really heat up the exhaust the fewer the regens.
Can you drive your truck around and have it function properly, regardless of how you use it? Yes. The question is, what does it take for optimum performance.
Although I did have a regen (saw msg) last Wednesday where I almost pulled over to make sure someone didn't steal my 6.7L and put in a 6.4L; truck was surging quite a bit.
I'm down 1+ MPG from this time last year and using more DEF but get it out on the interstate for nearly a tank of fuel and my MPG is almost exact to what it has always been.
City driving is torture; for myself and my truck!
I drive a mix highway, city, dirt, road, pull trailer !
I drive my truck hard, always! People say that i think im a nascar driver
I reset the lie o meter today and drove around a lot, it settled at 15.6
So you guys know, i am a welding technical advisor all i do is drive
From one plant to another all day
I burn a tank every 2 days
Why the change?
I may try a programer soon to fix my trottle lag and see if mileage improves
May help trans shift better.
Which reminds me the trans did the slip thing yesterday first time in a long time
