Two problems on a 99 expedition
Old Jun 8, 2011 | 01:11 PM
99EdeBauer's Avatar
99EdeBauer
Two problems I have been having one really only happens when it is hot out.. Whenever I hit a bump or have any movement I get a annoying creaking sound from the front of the truck. Kinda like a rusty metal hinge in a door? Second has been happening a bit longer but just as annoying none the less. I doubt they have anything to do with each other. When I am stopped and ready to turn ( mostly on right turns ) I get bad shudder in what seems to be the passenger front tire. Any thoughts or ideas would be appreciated.
Chris
Old Jun 8, 2011 | 01:12 PM
99EdeBauer's Avatar
99EdeBauer
*Movement in the suspension.
Old Jun 8, 2011 | 01:42 PM
High_Horse's Avatar
High_Horse
Chris
Both sound like ball joints...the creaking is the tension on the socket probably from lack of grease. Check the bushings on the control arms. For the price and what you get, I would get this, you can't go wrong with this price $180...
1997-2002 EXPEDITION Control Arms Ball Joints I Arm Pit on eBay!
Old Jun 8, 2011 | 02:21 PM
alloro's Avatar
alloro
I agree the creaking is likely the control arm bushings. If you want to confirm this, soak them with WD-40 just to see if the creaking goes away. The shuddering could be due to needing a front end alignment.
Old Jun 9, 2011 | 08:20 PM
ronjeremy6's Avatar
ronjeremy6
My 99 was doing the exact same thing, so I did what alloro suggested and the creak was still there. Ended up being ball joints.
abe
Mar 2, 2014 10:51 AM
WOOHAK
Jan 27, 2012 04:08 PM
fireresqdog
Dec 3, 2004 11:00 PM
Acamar
Nov 7, 2002 12:00 PM
