I have a 3L55 tag on my rear end of my 1996 f-150 but it appears that my front end is a DANA 3.54. Could this be correct? I need new outer yokes and spindles but I can't find the yokes so I am considering buying a used front axle from a 1995 bronco. Any help or suggestions would be appreciated.
That would be correct. It's very common and quite normal for the front gear ratio to be slightly numerically lower than the rear.
i know its not 87-96 but my girl is a 08 f150, 4 full door, tiny bed baby but need help
rear end is shot trying to figure out the spline i know this def says i have 8.8 ratio but guess i need spline info too so i can order new locker and gears..or do i? lmao
tags reads as follows
v807A
3L73 8.8 7k10
any help is greatly appreciated thank yall so much.
