I have a question to ask. Yesterday, I made a 150 mi rt drive that I have made three other times since I have owned the truck, as recently as last week. I have consistently averaged 18 to 19 mpg. Same weather conditions as previous trips I averaged 16 to 17mpg. The only difference, my factory installed bed cover was rolled up.
Has anyone else ever observed this or am I chasing moonbeams?
When I put the bed cover on my new truck I thought the mpg went down. Winter gas (gas truck)?
I have been watching the mpg lately and now it doesn't seem to make any difference.
I'd also like to know if a bed cover can alter mpg.
It's been proven that a bed cover does nothing for MPG. There is a high pressure bubble that forms in the bed when there is no cover that acts as if there is a cover.
It's been proven that the air "bubble" that exists behind the cab actually smooths out the airflow over the truck. Lowering the tailgate or using a flow-through tailgate prevents the bubble from forming and actually increases drag on the truck. Removing the tailgate all together has some improvement in mileage due to the decrease in weight but even that benefit is lost due to the increased drag of no bubble. This is counter-intuitive to most people as it would seem that the tailgate acts as a big parachute back there. This is simply not the case.
Of course there are many variables in the equation including overall vehicle aerodynamics, vehicle speed, altitude, etc. but the principle is sound.
I have heard the bed cover doesn't make any difference either. In 150 miles you have a lot of variables. Slow drivers you passed,did you use cruise control the whole time,even a small head wind. Your only talking 1 mpg,you said 18 or 19 to 16 or 17. If you drop more I would get concerned.
Looks like the bicycle on the roof rack kills a little too.
There could be other variables at work with the subject trip. A little headwind or crosswind not present on other trips, or something like that. Driving into even a mild headwind kills 2 or 3 MPG on my '11.
Windshields on modern trucks have a flatter angle (and probably better aerodynamics) than they did on older trucks, so that probably affects how the "bubble" in the rear works, and why the old tailgate down trick doesn't work on newer trucks like it seemed to with older trucks.
I remember trying various things with my '05 when I first got it. Tailgate down did indeed make the mileage worse. Hard tonneau made perhaps a slight improvement over no tonneau. Cab-high topper made a 1+ MPG improvement over the hard tonneau or bare box. Just my results as I remember them.
another little thing you might not of noticed, chevy came out with it first, but if you look at the top of the tailgates on most of the new trucks you will see either built into the metal or installed as a plastic tailgate cap, it will protrude past the top of the tailgate and have an over hanging lip going back of the tailgate cap
the top of the tailgate on this new dodge shows what I am talking about. that isn't there for styling its done to help the airflow past the truck as it goes over the tailgate, even the top back edge of the roof on some vehicles has a similar shape. some thing it might yield .5 mpg
Yea, they did awhile back and gate up is what I remember also because that allows the air bubble to form which allows additional air to flow over the bubble.
