I have a 99 7.3. I added the 6.0 a few months ago and can't say what my temp was before because I added the trans temp gauge at the same time as the 6.0 cooler. There is a major difference in the size of the two coolers. I can say towing my 10,000lb TT in fairly cool weather about 55 degrees outside temp, I did not get over 125 with the new cooler. About 1500 miles with several passes.... What year is your truck? The 99 is the one year they did not route the trans fluid through the radiator, so if you have a 99 I would get a larger cooler. Do you know what your trans temp is now?
[IMG][/IMG]
Same on my 2000, no cooler into the radiator. I added a Napa Ultra cool tranny cooler and it helped a LOT
