Steering column, wheel, ignition, etc.
Old Jun 7, 2011 | 03:36 PM
OneLong4x4's Avatar
OneLong4x4
Hi -
I have a 1990 F-150 SuperCab, 4x4, long box, 4.9L w/ 5speed.
The truck has a tilt column in it that was swapped in by a previous owner. The wheel was on 180 degrees off. I pulled the steering wheel to flip it around, but I found that there is a flat spot among the splines that won't allow such a simple fix. Anyone know of a "quick" way to get the wheel put on right side up? I am not seeing it. Maybe I am missing something?
Also, I am swapping in a new turn signal switch and re-wiring the ignition to a dash-mounted switch. The previous owner had a push button for the ignition crank function and you had to have the key on to start the truck. After a number of stuck starter relays, I am going to completely remove the ignition cylinder from the steering column. I have a typical off/accessory/run/start switch to use.
I am wondering if anyone can comment on the function of the little "finger" contact block that attaches to a black/pink wire and makes contact with the ignition key cylinder. I am guessing that might go to the "key-on" buzzer? Anyone? I hope it is something I can just cut out of the wiring.
Hope someone can help -
C.J.
Old Jun 7, 2011 | 06:07 PM
Edgethis's Avatar
Edgethis
You can prolly disconnect the pitman arm and check the number of turns to make sure the steering is centered. that should fix the steering wheel.
That little finger I believe does go to the buzzer chime.
Old Jun 9, 2011 | 10:36 AM
OneLong4x4's Avatar
OneLong4x4
Thank you for the reply.
I did find in the service book that the "finger" contact is the key on buzzer, as you had said. Thanks!
As far as the pittman arm and re-centering the steering, is this a procedure you have done? Do I need to disassemble any of the steering linkages or just remove the cotter pin and nut from the steering box/pitman arm connection? It looks like I need to use a two-jaw puller to get it apart. Will any old puller work or is space limited? Or would a pickle-fork & air chisel do it?
Thanks again -
C.J.
Sunline Fan
Aug 23, 2022 06:13 AM
Tewkman
1997 - 2003 F150
Nov 23, 2013 09:34 PM
timmygyu
1978 - 1996 Big Bronco
Feb 27, 2013 06:40 PM
Mad.Scientist
Aug 26, 2009 12:27 PM
82-100
Jan 15, 2009 08:15 PM
