Eng longevity and CCV
Old Jun 7, 2011 | 01:14 PM
smokersteve's Avatar
smokersteve
Will a CCV re-route with the catch can or re-route to an open line to the ground increase the engines longevity over the oem set up?
This includes an engine with an egr delete.
I would guess that the oem set up helps to lubricate vavles.
Thoughts???
---EDIT--- with stock intake filter that is actually changed, and proper oil intervals.
Old Jun 7, 2011 | 01:52 PM
steelhead2's Avatar
steelhead2
imo all the oem setup does is gum everything up,including aftercoolers and intake tracts.since removing mine a couple years ago my intake tubes are nice,clean, and dry.also theres no oil coming out of any of the boots.
Misky6.0's Avatar
Misky6.0
I think the CCV reroute keeps the oil residue that otherwise
accumulates in the intake tube from getting into the
turbo vanes and gumming things up.
EDIT: Steelhead2; great minds think alike!
Old Jun 7, 2011 | 04:03 PM
npccpartsman's Avatar
npccpartsman
I'll take the semi-contrary opinion here. I have no EGR and no CCV reroute and I've had no problems with anything gunking up. I have, however, seen problems from incorrectly done CCV reroutes that caused engine problems from excess crankcase pressure. Besides that, I hate pulling into a drive-thru with a tail wind and having that stinking mess blowing into the cab and drive-thru window--LOL. I had one and took it back off.
Old Jun 7, 2011 | 04:06 PM
smokersteve
I also have had 0 issues with oil in the intake. If I was popping off boost tubes then I would go with one of the 2 ways to mod the ccv.
But I still like the idea that the oil lubricates the valves.
Old Jun 7, 2011 | 04:22 PM
Ian123's Avatar
Ian123
I think its a great mod if done correctly but like npc said if you do it wrong you can cause problems. Thats why I'm afraid to re-route mine and am just going to leave it alone
Old Jun 7, 2011 | 07:24 PM
steelhead2's Avatar
steelhead2
Ian,get rid of it!. I am currently in the middle of an oil cooler job and you wouldn't believe the oily goo I'm trying to clean out of the intake.mines been done for two years,so it had five years to accumulate in there.I still have my egr on but you can tell the difference between oil and what the egr puts in there.as for doing it wrong you really cant.do it,you won't regret it for a minute......id have to agree with you misky!.
Old Jun 7, 2011 | 10:35 PM
BLADE35's Avatar
BLADE35
mine was full of goo to
lots of purple power and a pressure washer lots of cleaning
whatever your egr valve looks like pretty safe bet the intake manafold is just as bad if not worse
Old Jun 8, 2011 | 01:20 AM
smokersteve
The egr makes it very bad situation because of the carbon sticks to the oil. I would like to understand the more about the ccv effects with out the egr system and a good air filter.
Old Jun 8, 2011 | 05:30 AM
NYC F-350's Avatar
NYC F-350
International dumps the CCV straight to the ground, so do I.
Old Jun 8, 2011 | 11:51 AM
smokersteve
NYC Did the truck run better? Or just a change at all? besides less oil in the intake.
Old Jun 8, 2011 | 12:01 PM
NYC F-350's Avatar
NYC F-350
Didn't change the way it ran, just the absence of oil in the intake is what I was shooting for.
Its right under the drivers seat. No dips where moisture could collect and restrict the hose. Every now and then, if the breeze is just right, I get a whiff of it, its not too bad.
If someone asks me what it smells like I tell them that it smells just like a diesel truck is supposed to smell like.
Old Jun 8, 2011 | 01:16 PM
Ian123's Avatar
Ian123
Exactly. I don't see why people are so 'offended' by the smell. The only time I smell diesel in my truck is at idle, big deal
Brian Uhlenhake
6.7L Power Stroke Diesel
86
Oct 22, 2023 03:04 PM
Sullid01
Dec 28, 2014 11:32 PM
caiati
Aug 16, 2012 04:21 AM
Piolet
Aug 8, 2011 10:41 AM
F250_
Jul 29, 2007 06:30 PM
