Modular V10 (6.8l)
v10 temperatures
Old Jun 6, 2011 | 01:13 PM
klr650goldwing's Avatar
klr650goldwing
v10 temperatures
I searched for this and couldn't find it for V10s.
I have a 2004 V10,4X4 CC LB AT
What should the temperatures be for the engine coolant, transmission fluid and the transmission itself?
I know this might very a little because of ambient temperatures, and whether or not I'm climbing a slope etc. but what is a ballpark average?
What should these same temperatures average while pulling a 10,000lbs 5th wheel?
Thanks in advance.
Greg
ps From this site I'm learning that stock gauges aren't very accurate and I'm planning to buy some much better gauges soon. However, I still need to know what average temperatures should be in order for those new gauges to do me much good.
Old Jun 6, 2011 | 05:22 PM
mwsF250's Avatar
mwsF250
I would expect the engine coolant to stay at 190-210. The thermostat should control fluid flow to radiator to maintain this. The temp in the radiator itself will vary all over the place.
As far as the transmission fluid, it depends on how hard you're working, and also the ambient temperatures.
When towing on flat ground, my transmission seems to hover about 70-90 degrees over ambient. (150 on 70 degree day, 190 on 110+ degree day). After a looonng hard grind up a serious grade (like Donner pass), or in lots of stop and go traffic, it may get up to 150 over ambient, but that is just for a few minutes.
Old Jun 7, 2011 | 08:06 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Not sure about coolant, but with an electric gauge sender stuck in the "test" port of the 4R100 tranny, my tranny never gets above 150 degrees even in 90+ degree temps. If I really load the truck, it MIGHT get up to 180. I've heard that around 220 is way too much for a 4R100, and it's probably cooked at that point, and needs at the very least, a fluid change immediately.
I do have a huge tranny cooler behind the condensor.
Coolant, should get much above 200, the stock t-stat is 195 I think.
Old Jun 7, 2011 | 08:52 AM
Bbasso's Avatar
Bbasso
in my 05 V10 van,
water- 195-208
trans- 165-185
higher temps are towing up to 7500lbs.
Bone stock other then Mike's 5 Star tune.
Old Jun 8, 2011 | 01:03 PM
Monster-4's Avatar
Monster-4
According to Mark Kovalsky 4R100 temps of 220F is safe to run all day lone. 250 is safe for up to a half an hour at a time.
https://www.ford-trucks.com/forums/1...l#post10408026
