Likelihood of tuner causing HPOP failure?
Old Jun 6, 2011 | 09:25 PM
BLADE35's Avatar
BLADE35
andy Iv seen some of your other posts and it seems like this shop is having a hard time If it was my truck Id get it out of there and find a good ford tech to fix it they maybe doing more damage than good just my 02 good luck
Old Jun 7, 2011 | 06:52 AM
hubler13f's Avatar
hubler13f
Your not kidding from a bad PCM to a bad HPOP diagnosis for the same problem in the course of a week. As someone else mentioned I think your being good buddied to death.
Old Jun 7, 2011 | 07:26 AM
npccpartsman's Avatar
npccpartsman
I have serious doubts about their diagnostic capabilities on a 6.0 myself. Even my cheap azz would have gone to a dealership by now for at LEAST an electronics diagnostic and reflash to rule that out and a HPOP system test to double check that the pump is weak and that it's not a system leak. Multiple PCM failures are simply unheard of and as far as the tuner causing them, my PCM has been flashed more times than I can count and I've never had a problem. I don't even go back to stock, I just change tunes.
bill wilson
Oct 25, 2014 09:37 PM
polosabre
Sep 21, 2013 08:39 AM
Dr. Johnson
25
Oct 24, 2012 11:47 AM
lud04X
Jan 2, 2012 02:36 PM
F 250 6 liter
Nov 8, 2010 02:43 PM
