CCV Mod
Old Jun 6, 2011 | 12:53 AM
Superduty_7.3's Avatar
Superduty_7.3
CCV Mod
While i am working on fixing my truck i was really thinking of doing the CCV mod i hear about. What is the best way to do it? Is there any maintence involved after it is done, and does anyone know the stock intercooler pipe sleeve diameters mine need replacing and i am looking at the RifRaf Diesel set just dont know what diameters i need?
Old Jun 6, 2011 | 01:49 AM
VegasFordSD's Avatar
VegasFordSD
A lot of people just run the hose out the back along the frame rail... I did a "catch can" on mine and routed it back into the factory location in the intake. here is a picture of my can.
If you run this type of setup, only maintenance would be draining the collected oil occasionally...
Here is a link with some info for you to decide what route to take
https://www.ford-trucks.com/forums/4...ccv-mod-2.html
The diameters of your IC boots can vary, depending on the year of your rig. Best bet, pull them off and grab a tape measure
Good luck with everything bud
Old Jun 6, 2011 | 01:59 AM
Josh88Ford's Avatar
Josh88Ford
http://www.riffraffdiesel.com/mm5/RE...t_Ordering.pdf
