Help on steering play.
Old Jun 5, 2011 | 02:36 PM
mmarmino's Avatar
mmarmino
Hey everyone, my F100 has a little bit of slop in the steering and i can really tell when i get up to speed. its not because of the "rag" joint, because i can see that the play is in the steering box. I also see that there is what looks to be an adjustment screw and lock nut on top of the box. Any ideas? thanks.
Old Jun 5, 2011 | 03:11 PM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
The adjustment screw sets the preload for the sector shaft...do not mess with it! If you overtighten it, the gearbox will lock up tight.
Loose steering can be caused by worn sector shaft bushings, but also by worn tie rods/tie rods ends, worn draglink, worn king pins.
What year is the F100, is it 2WD or 4WD?
Old Jun 5, 2011 | 07:15 PM
mmarmino's Avatar
mmarmino
my f100 is a 1970.
Old Jun 5, 2011 | 07:58 PM
MIKES 68 F100's Avatar
MIKES 68 F100
you can figure what is worn by haveing a freind sit in truck and steer side to side just play. crawl under truck and look where movement stops .
Old Jun 6, 2011 | 07:24 AM
mmarmino's Avatar
mmarmino
yeah im gonna try that today to pinpoint the play...thanks.
Old Jun 6, 2011 | 07:54 AM
Unimog005's Avatar
Unimog005
"Slop" can also come from the steering box coming loose from the frame.....make sure all the bolts are tight so it can't move around....
Old Jun 7, 2011 | 11:11 PM
jhooch's Avatar
jhooch
If it is indeed the gearbox, I recommend having it rebuilt by someone like Redhead Steering gear in Seattle. Like NumberDummy says, messing with the adjustment screw is only going to make it worse.
Old Aug 5, 2011 | 04:29 PM
mmarmino's Avatar
mmarmino
I know its been awhile but i figured out that there isn't any actual play in the steering. Its actually just the fact that the steering is tight. Meaning if im in a curve and release the wheel it stays turned, it doesn't return to center. that's why it seems like im fighting it at higher speeds. any ideas?
Old Aug 5, 2011 | 04:38 PM
MIKES 68 F100
it should pull back , get under there with a grease gun and go nuts . things might have just dried out .
Old Aug 5, 2011 | 08:45 PM
jhooch's Avatar
jhooch
They king pins may be frozen, had this problem on my 65 SWB plus I've got a 76 F100
4X2 donor truck in my shop right now with both pins froze up solid. Will not turn at all. You may have to tear them down and replace pins. Good a time as any to install 73-79 spindles with disc brakes.
Old Aug 5, 2011 | 10:46 PM
corytcline's Avatar
corytcline
had this problem in a 69 ranger replaced the drag link after finding slack there and it helped but did not completely fix the problem. I agree with number dummy could be a combination of things.
texasjack
40
Jul 30, 2023 12:04 PM
marmon77
23
Jan 5, 2013 10:44 PM
jcascio
Apr 13, 2009 09:14 PM
Brats
May 29, 2007 06:10 PM
ahawes
Aug 8, 2003 11:42 PM
