Sponsored by: Real Truck
mass airflow
Old Mar 25, 2003 | 05:40 PM
maxcat0198's Avatar
maxcat0198
mass airflow
can someone tell me what a mass airflow calibrated for larger injectors does.i mean does this mean you have to replace your injectors with larger ones.I want to replace my current mass airflow with a high performance one like the granatelli i dont know if you order certain sizes or they are all the same.the one i saw just fit the engine size thats it and boosts hp ...also does this mean i need a bigger throttle body i want one of those to .....need some extra ponies here!
Old Mar 25, 2003 | 06:33 PM
V10KLZZ71S's Avatar
V10KLZZ71S
mass airflow
MASS Air sensors are calibrated to a certain size inj.You can get one calibrated to your stock injs, but i feel that the gains wont be as good as also having larger injs.This has nothing to do with the throttle body. But a larger throttle body will generally give you 8-12 hp. Mass air sensors "senses" air coming into the engine, then adjusts the air fuel ratio.Like i said earlier you can get one without larger injs and you probaly dont need larger injs unless you do some serious exhaust mods.Throttle body controls the air going in the engine, sorta like a carb but without fuel.
Old Mar 25, 2003 | 07:16 PM
maxcat0198's Avatar
maxcat0198
mass airflow
ok im starting to get it now where do i find such a thing the place u sent me to before seems to be for lightnings only with lots of engine mods i just want one for my stock motor i will go with a bigger one that is for larger injectors where they are actually (stock)and what size am i looking for thanks.....
Old Mar 25, 2003 | 08:08 PM
V10KLZZ71S's Avatar
V10KLZZ71S
mass airflow
While JDM specializes in Lightnings, i am sure they can answer any questions you have.
smacDiesel
Feb 4, 2010 09:54 AM
dudeiscool654
1997 - 2003 F150
Dec 16, 2009 06:58 PM
NitrousAl
Jan 1, 2008 09:59 PM
84Maztang
May 31, 2004 04:44 PM
ssKable
24
Jun 25, 2003 02:34 PM
