To oil spray, or not to oil spray?
#46
Yes. Its used motor oil. I have about 15 qts of oil in my garage so I figured I'll put them to use and I also hate rust.
I will check the underside for the next few weeks and re apply if needed. I'm planning of oiling at least once a year.
#47
#48
Here in Canada there are a lot of rust prevention companies the top two being Krown Rust Control (h t t p://www.krown.com/process.php)and Rust Check. (h t t p://www.rustcheck.ca/index.php?option=com_frontpage&Itemid=71)I work at a body shop that is a Rust Check dealer and I can say from what I have seen, it is well worth the money....
One thing I will say is that the product is not as important as the application. The best product in the world is junk if it isn't where it needs to be.
A few other names are rustblock, oil skin and ziebart. You couldn't pay me to use Ziebart though.
#50
Snowseeker -
I just resprayed the undercarriage of the Ex with used oil over the weekend.
First thing I noticed was there were a lot of loose rust falling off the frame of the Ex. I was not sure if this was a good or bad thing -- not certain if the oil from last year accelerated the rusting process.
But per your comment above, sounds like its normal to have loose rust due to the oil. It might take a few years to get rid of majority of the rust chunks.
#51
#52
#53
Snowseeker -
When I saw this thread bumped up I hoped someone had a one year update. Yes it is normal to lose the loose rust within the first year or two after being sprayed and I believe I mentioned this earlier in this thread. The oil kills the rust which in turn makes the flaked up rust loosen up and fall off. In the end you will have all solid good metal with an oil coating and no loose and flaking rust left killing the frame.
#54
Thx for all the help.
#56
You've got to be sure to cover EVERYTHING. If you leave a seam anywhere (even on the other side of the panel) where water can get in, you'll just create a place for water to accumulate and it will eventually come through the paint.
#58
#59
It's not so much whether you brush or spray IMO. For instance, I painted all around the pinch joints on mine, but because water can get up above and inside the pinch joints from underneath, it isn't holding up as well as I'd hoped. Water is working its way out through the rocker panels on both sides. I'm contemplating spraying fluid film or just oil on the back side to see if that slows it down.
You can probably get most of the frame and the axles enough to last for a little while. Surface prep is the most important part of POR-15, though, and there is A LOT of surface under there to prep.
