c-6 and 8.8 wanna change gears in rear end
i have a 92 f150 with a 4x4 c6 3spd and a 8.8 rear they work fine but i want something more torquey off the line... I go to the local mud holes and attempted to put my cousin out (a chevy of course lol) and the 4wd would even spin a tire in the dirt and the 2wd would spin a tire but it was struggling to even do that, much less easly pull him out with out snatching hard! Any ideas on what gears for the rear end will help with this?
Thanks.
Thanks.
on
you probably have 3.08's.it's an economy gear but a total slug.
the easiest and cheapest way to solve this is to head to your local salvage yard for a whole rear axle with 3.55's.you'll need new U-bolts and an afternoon wrenching then she'll feel like a truck.
with just a C6 though,you'll likely take a 2-3mpg hit-depending on your average speed,but this will solve your issues.
unless of course your running w/a lift an larger than 31" tires? if not,that will make ya smile.
i have a 9 inch lift with 38 inch super swampers the rear end came from a junk yard out of a early 90's model mustang is what i was told... i only drive it in town and hate having to gun it to get off the line or to try to spin a tire in the sand reall just wanna get off the line alittle faster and if i have to pull someone out to be able to actually pull and not just bog in place its kinda embrassing lol...
ok thanks i went outside to look at the rear end and tottally forgot about the rear end tag on the diff cover and it said it plan as day 3:55 8.8 now that i know that i dont wanna go crazy with the gearing i just wanna get alittle more edge.
Should i go with the 373's?
And my motor is a 302 mostly stock but has a alum intake 4b carb and all MSD ignition.
well remember the front needs the same gears as the back. get some 5.13-5.38 gears, you will need a new front carrier due to the D44 having a carrier break at 3.92 and down. as for setting the gears up i recommend calling around and getting some quotes at a shop. gear setup requires special tools and skill and if not done properly can turn all that money and effort into a pile of worthless steel.
going with this gear change will make your rig into a beast both onroad and offroad. You wont be disappointed
