This goes back to my 5-26-11 post "front end woes" thanks to someone ( i forget names) I was able to get the steering wheel straight.
First, if you adjust the steering box on top where the nut and screw are do you do this on the ground or with the front wheels off the ground ?
Second, on top of the brake housing there is a nipple that a hose runs from and to another nipple up by the frame, is this for the ABS or what ? And does fluid ever come out of it ? Mines missing and I looked at the other side to see where the hose connected.
Thanks again
Also, on the inter wheel cover (or whatever it's called) there are two, one on each side, that liikes like are connectors for some type of wiring connections. Does anyone know what these are or are for ??
