how much blow by is normal
Old Jun 2, 2011 | 07:33 AM
ray pampena's Avatar
ray pampena
i picked up a 7.3 with a hypermax turbo on it. how much blowby is normal when you pull out the breather pipe in the valvecover?.. its in the valvecover now because of the turbo.
thanks
Old Jun 2, 2011 | 09:38 AM
ray pampena
also, its smoking out the exhaust when you rev it and hold it. it misfires then smokes.. when it doesnt misfire it doesnt smoke. im hoping its the injectors and injection pump.
the blowby worries me more unless thats normal
http://www.youtube.com/user/PampenaM.../0/fWFxR3ecXaM
Old Jun 2, 2011 | 09:48 AM
Aune163rd's Avatar
Aune163rd
Blowby is normal. it shouldnt come out in puffs but a steady stream. personally, my 84 has no blowby because of the recent complete rebuild it had done. The smoke, what color is it? if its black then your IP might be turned up a bit too much, if its misfiring with grey smoke, you got an IP/Injector problem.
Whats the spraying hitting the ground, cant quite tell lol cause im a little blind right now.
Old Jun 2, 2011 | 09:54 AM
Aune163rd's Avatar
Aune163rd
I studied that video a little closer with the help of a friend, he says it was greyish white smoke, sounds like a IP issue because if it was burning oil, it would be blue smoke.
Old Jun 2, 2011 | 10:14 AM
ray pampena
its grayish smoke. it only smokes once it starts to missfire. if i hold it just below that rpm it doesnt smoke at all.
the spraying hitting the ground is water from my garden hose cooling system lol.
the blowby is a steady stream its not pulsing so its from all 8. but its a pretty good amount. ill try and get a vid of that later
Old Jun 2, 2011 | 02:03 PM
Phy's Avatar
Phy
How much blow-by is normal?
A whole lot less than mine...
Old Jun 2, 2011 | 06:30 PM
Otahyoni's Avatar
Otahyoni
Anyone think the diesel kleen trick would help?
Ray, try removing your fuel filter, dumping out the diesel and filling it with Diesel Kleen (comes in a gray bottle, available at your parts store) and put it back on. Start it and run in for a few seconds (not sure what the official time frame is, but you want the injection pump and injectors full of diesel kleen) then shut it off and let it sit for a few hours (overnight would be better).
Old Jun 2, 2011 | 07:22 PM
Jayme Duty's Avatar
Jayme Duty
I do not think that diesel kleen will help but it is a valuable try. i would spend the $8 and try that before i bought an IP
Old Jun 2, 2011 | 07:46 PM
wreckinball's Avatar
wreckinball
i am slightly color deficient but damn if that doesnt look blue and mirror a CDR valve issue. Have you pulled it off and cleaned it? What does the inside of the intake look like, all fouled black i bet. Also what the hell happened to the front of the motor? the cooling fan is destroyed. Did this come from a JY?
Old Jun 2, 2011 | 10:09 PM
ray pampena
it still does that exhaust smoke even with that CDR disconnected. heres a vid of the blowby smoke.
the motor was out of a junk truck. it was a farm truck with low miles but im sure it had a lot of run time
YouTube - ‪7.3 idi blow by‬‏
Old Jun 3, 2011 | 06:23 AM
Otahyoni's Avatar
Otahyoni
Maybe i'm wrong, but that doesnt seem like that much....
Anyone else?
Old Jun 3, 2011 | 03:30 PM
ray pampena
anyone feel like doing a comparo on their truck for me? maybe someone with a fresh engine? id hate to put this in the truck if it needs a rebuild. im not sure what normal is with these engines
Old Jun 3, 2011 | 04:15 PM
Aune163rd's Avatar
Aune163rd
cant use my truck because there is no blow-by cause it was freshly rebuilt, i would try having my buddy logan get the 86 started but it needs quite a few things for that to happen. I will say this bout the CDR: You need to soak it in something like white gas or kerosene to break up all the soot and oily crap in there, then throw it back on....the CDR valve controls crankcase pressure and takes the oil mist that these engines produce and puts it back in the engine....that has to be in working order for the engine not to burn that oily mist that is in passes the intake into the combustion chamber.
Old Jun 3, 2011 | 04:16 PM
Aune163rd's Avatar
Aune163rd
x2 on not that much blowby, that looks perfectly normal to me.
Old Jun 3, 2011 | 05:32 PM
ray pampena
when my cdr is hooked up i dont see any blow by. its onle when i take off the hose. on your new engine.. it has no blow by even with that hose off? thanks for the help guys
trk98
71
May 10, 2021 08:24 AM
billcollector
Apr 17, 2021 08:58 PM
BackyardIdaho
Feb 20, 2016 09:18 PM
Nathan Plemons
Apr 3, 2010 10:31 PM
Jim88554
1997 - 2003 F150
Nov 17, 2008 05:39 AM
