Last edit by: IB Advertising
See related guides and technical advice from our community experts:
Browse all: Wheels & Tires How-Tos
- How to Determine Proper Tire Pressure
Guide to diagnose trouble and recommended solutions
Towing and tire pressure
When hooking my travel trailer up to my Expedition, I would always bring the tire pressure up to the manufacturers max PSI of 44. When not towing, I would lower it to 40... This was recommended by my trailer dealer years ago.
I have a stock F250 Super Duty Super Crew... should I follow the same guidelines? Bring tire pressure up to max prior to pulling? Or are there other guidelines?
80 psi is high pressure. I pump my tires to 90 psi, but I load up to 10,000 lb on my bed.
Good tire manufacturers do have charts for each tire that will recommend the pressure for the load, meaning you should find out actual weight per axle and inflate it accordingly.
Rule of thumb is to find out what percentage of max tire load you are carrying and inflate with the same percentage of max pressure.
More pressure = more load capacity
But too much results in rough ride and reduced traction
Optimal pressure = best ride quality and handling
I have big tires so can run quite a bit lower for the same load capacity. The Goodyear DuraTrac E rated tires I have are max load (3800+) at 65 psi.
I've always aired tires to give best tire wear. Over inflation for the load results in excess wear to the center of tread, under inflation wears the shoulders (and overheats and damages the tire carcass).
I used the chalk on the tread method to find optimal psi for various load conditions, and then verified the load capacity was adequate for those pressures.
I run between 40 and 50 in front, and 40 to 65 in rear.
When I'm loaded the rears get pumped to the max or a few PSI under. Depending on how I'm loaded I'll run less pressure up front. When unloaded the rears get aired down for an even contact patch and to get better traction.
