Modular V10 (6.8l)
Code 1151 and random sensor
Old Jun 1, 2011 | 08:52 PM
NLAuto's Avatar
NLAuto
Hi I was recently pulling a car from VA to NC and blew a plug out off the head gouged the cylinder wall exc... (6.8 V10) Truck had about 300k so I pulled the engine rebuit it and the trans. I put the engine back in and everthing is good but this code I was told at first it was an egr problem so I checked the vacume lines, reg valve, egr valve, egr tube, and replaced that sensor still nothing. So I go back and they try and tell me I have a rear set of o2 sensors and that one of them are bad but I have no rear o2's. So im lost PLEASE help
Ill get a pic of the sensor that I cant find a place for it is up front near the thermostat housing it has the thread lock on it from the factory so I assumed it would leak or something when I started the engine but nothing all my guages work im not losing any fluids idk.
Thanks ahead of time Joshua
Old Jun 2, 2011 | 07:02 AM
projectSHO89's Avatar
projectSHO89
This is unlikely to be an EGR fault unless the EVR valve is dumping unwanted exhaust flow into the intake.
You only have two O2 sensors, one on each exhaust manifold/downpipe before the converter. The heavy-duty trucks don't use any sensor after the cat.
Your fault code, P1151, typically is related to the O2 sensor on the driver's side. Either the sensor is bad or there's something wrong with that side of the engine in regards to mixture control. It might also be due to an exhaust manifold leak on that side.
Old Jun 2, 2011 | 10:03 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
What year truck is this?
Old Jun 2, 2011 | 02:24 PM
NLAuto's Avatar
NLAuto
Sorry the truck is a 1999 F-250 superduty with the 6.8 V-10
The parts store said something about its not the sensor because its reading lean idk for sure I know its code 1151
Old Jun 2, 2011 | 02:51 PM
NLAuto's Avatar
NLAuto
Here is that sensor I cant find a place for. Maybe im blind and just overlooking it idk.
Thanks again
Old Jun 2, 2011 | 03:00 PM
krewat's Avatar
krewat
Looks like a coolant temp sensor. What are the actual wire colors on the harness for that, I'll try to check it against my 2001 EVTM and see if I can figure it out.
Old Jun 2, 2011 | 03:04 PM
NLAuto's Avatar
NLAuto
yellow/green and white/red
Thats what I thought to but I just cant find a spot for it and theres no leaks ?
Old Jun 2, 2011 | 06:26 PM
projectSHO89
The ECT should have a red/white and a yellow/red wire.
Old Jun 10, 2011 | 01:20 PM
NLAuto's Avatar
NLAuto
lol it was a knock sensor under the first intake runner
96halfton
Nov 6, 2016 04:31 PM
BigBlocker0248
Feb 29, 2016 06:20 PM
Schwinn240
13
Mar 25, 2010 06:57 PM
lattices2
1978 - 1996 Big Bronco
Aug 19, 2005 07:27 PM
SinisterSS
Jan 28, 2004 04:12 PM
