p0381 code on a 2002 f350 7.3l diesel powerstroke
hi everyone!
i have been having more trouble than normal to get it started on cold and not so cold mornings, if i plug it in it will start fine. i was on the street and suddenly it lost power as if it was not getting fuel, then it would get normal for a little bit or in the park position but when set on drive it would not have power. the next morning started just fine for a couple of minutes then turned off,
the truck has new fuel pump, new fuel filter, new gpr, i checked fuses, it will crank as much as i want to but it does not start, any help would be appreciated!!
thank you!!
thank you!!
Where did you get the CPS? The ones from the parts stores tend to cause more problems than they fix. Stick with a Ford or International part when it comes to the CPS.
When you try to start without it being plugged in, does it smoke a bunch while cranking? If so, what color smoke? How many miles on the truck? How often has the oil been changed during it's life? Got a chip or tuner in the truck?
People have trouble with the autozone CPS and most went back to ford. If that don't work it mit be the pedal senser. Dose it rev up?
