Sponsored by: Auxito
68mph shake
Old Jun 1, 2011 | 12:17 PM
FordManDan30's Avatar
FordManDan30
68mph shake
At 68 mph a shake starts and I think it originates from the rear end. I had the back two tires balanced and the problem still exists. This is a truck that was rolled up on the passengers side at one time. I bought it after the accident at 1/2 NADA value. 2003 F150 extended cab 4x4 103,800miles. Any ideas
Old Jun 1, 2011 | 01:57 PM
Bluegrass 7's Avatar
Bluegrass 7
Look for a problem with the brakes on one side.
Jack up the rear off the surface so the rear hangs free, block the front wheels and run the rear up in speed to see if the vibration comes in.
If yes, remove the wheels and run it up again to see if the vibration is still there.
If yes remove the drums or disc and do it again.
This eliminates or proves as you chase the problem.
It may even come down to the drive line.
Do it all safely and under control.
Good luck.
myblkex
Jan 18, 2017 06:11 PM
myblkex
Modular V10 (6.8l)
Nov 19, 2013 07:17 PM
Jayeich1977
May 9, 2013 06:15 AM
spoogie
1997 - 2003 F150
27
Jul 3, 2009 06:32 PM
barno68
May 11, 2009 08:12 AM
