Exhaust
Old May 31, 2011 | 10:55 AM
openexcess's Avatar
openexcess
Exhaust
This post was posted in the superduty section and I was advised to move it here. This is what I want to know
I have a 04 F250 6.0 PS and was wondering if it would hurt to unbolt the exhaust right before the muffler or cat. (or cut it off) I plan on getting a full MBRP exhaust but not for another couple months. will this hurt the performance of the truck or should I just leave it? I want to get rid of the cat and the muffler if possible. I ahve an intake, but I do not have a tuner. can this be done without causing any damage to the motor?
Old May 31, 2011 | 11:42 AM
Ian123's Avatar
Ian123
Don't see why it would hurt anything, but it would be pretty loud and you would get soot all over the bottom of the truck. Also, in a few months when you spend several hundred on a full exhaust you will probably be disappointed since it will end up being quieter
Old May 31, 2011 | 11:58 AM
sarnott140's Avatar
sarnott140
why not just leave it untill you get the exhaust?
Old May 31, 2011 | 04:24 PM
openexcess's Avatar
openexcess
LOL loud is good, dont mind the soot i can wash the bottom off.. It doesnt blow any smoke out at all anyways so it wont be too bad.
To be honest I am bieng impatient. I just want to make sure it wont hurt anything with the lack of back pressure and stock tune.
Old May 31, 2011 | 04:43 PM
sammy77's Avatar
sammy77
It'd be a pain to clean off all that crap off the bottom of the truck, otherwise it's your truck unbolt it, if you don't like it reinstall it.
Old May 31, 2011 | 05:12 PM
openexcess's Avatar
openexcess
can I unbolt the cat and the muffler, or just the muffler? like i said i just dont want it to run lean or damage the motor form no back pressure
Old May 31, 2011 | 05:45 PM
sammy77's Avatar
sammy77
I have neither a cat or muffler on mine and many here have the same with no issues. If your state has any type of inspections leave the cat on.
Old May 31, 2011 | 05:49 PM
openexcess's Avatar
openexcess
i know alot of people are running no cat no muffler but there is a pipe to accumulate some sort of back pressure. Im talking about leaving it a short pipe (right before the cat) so alot less backpressure
Old May 31, 2011 | 07:48 PM
BRay09's Avatar
BRay09
So why not just cut the cat and muffler out and weld in a pipe? Keeps the full exhaust and you won't have to worry about "no backpressure"
