Offroad & 4x4
Whose lift kit is this?
Old May 30, 2011 | 10:56 PM
ninerM1000's Avatar
ninerM1000
Hi there,a little new to lifted trucks. Bought a 2011 F350 6.7 used out of the U.S.and just trying to figure out which lift kit is on my truck. Been doing a little research and I think it might be a superlift. They use the bilstein shocks with there kit. Any help would be appreciated,seems there's a very knowledgable group of guys on here. I know my truck is a bit of a princess compared to some of the beasts on here,still want to learn more about the sport. Thanks.Here's a few pics of the lift. utf-8BSU1HMDA0MjcuanBn.jpg picture by ninerM1000 - Photobucket
Old May 30, 2011 | 11:19 PM
Ford4X4ingboy's Avatar
Ford4X4ingboy
Its hard to tell off just that picture. I did notice the CST and know they do lifts. Ford 4WD F-250 | F-350 CST Performance Suspension - Lift Kit, Lift Spindle, UTV Suspension Kit, Shock, Upper Arm - Chevy, Ford, Dodge, Nissan, Toyota Check out those lifts and see if that helps.
Old May 30, 2011 | 11:43 PM
ninerM1000's Avatar
ninerM1000
Ok. Checked them out. I do have CST stamp on the steering stabilizers. There kit recommends 35" tires. I'm running 37". There lift is 4.5" in the front and 2" in the rear. I'm pretty sure mine is 6" in the front with 4" blocks in the back.Can't see any markings on the lift arms.
Old May 31, 2011 | 12:27 AM
fatdan460's Avatar
fatdan460
should be fine on the streets, but if you do go out flexing it up or hitting whoops and dunes you are going to mangle some sheet metal. it shouldn't be so bad with the coil and radius setup, but i know for sure the leaf spring trucks kill fenders with small lifts and big tires.
have you taken any measurements at full lock of the steering to see how much clearance you have between the front and rear of the front fenders and the tires????
Old May 31, 2011 | 08:31 AM
alpha/omega's Avatar
alpha/omega
Just a stab in the dark but Id say its YOUR lift kit
Old May 31, 2011 | 08:56 AM
Ford4X4ingboy
Haha Like!
Old May 31, 2011 | 12:24 PM
ninerM1000's Avatar
ninerM1000
Ok,I was just checking. I thought somebody on here had lost there's. I woke up one more and my truck was sittig a little higher than normal. LOL!
Old May 31, 2011 | 08:32 PM
whack&stack's Avatar
whack&stack
Hello Captian Obvious. j/k just jealous cause you beat me to it. to the op good lookin ride
Old Jun 1, 2011 | 09:45 AM
alpha/omega
Ok so I looked at the pics....
now I want to gouge out my eyes with a bimetal holesaw marinated in lighter fluid.
Please for the love of God tell me some junky isnt selling a lift kit with a "horizontal stabilizing anti-****out stacked lift block third ubolt"
Please post pics of your wife/girlfriend quickly before I end up like Johnny Depp in Once Upon a Time in Mexico.
Last edited by tjc transport; Jun 1, 2011 at 04:36 PM. Reason: and you know you can't say that either
Old Jun 1, 2011 | 10:43 AM
fatdan460's Avatar
fatdan460
Old Jun 1, 2011 | 10:58 AM
alpha/omega
bwahahahahahahahh*gasp*wahahahahahhahah!
Old Jun 1, 2011 | 10:47 PM
ninerM1000's Avatar
ninerM1000
Like I said I'm new to this. Do you have a pic or can explain the proper way to do this ?If its something I can build,better yet.
Old Jun 2, 2011 | 01:23 AM
whack&stack
well the stacked blocks are bad. since its a street ride a block is no big deal if you were going to wheel it hard the block should be replaced for a full leaf spring. you can see the stacked blocks where the silver block sits on the stock spring perch then the lift block on top of it. you should switch the blocks out for one solid block looks like from the pic you would need a 4 or 5 inch block. the stabilizer i am not sure what the big hang up there is most on the market are sold horizontilly all they do is mask steering issues but here is your other option. running a stabilizer that runs with the steering linkage (see pic) the 3rd u-bolt holding the real u-bolts is just stupid tighten the u-bolts appropriatly and its not needed. 2nd pics shows what you need your lift block set up to look like. 1 block and just 2 u-bolts.
Old Jun 2, 2011 | 03:44 AM
ninerM1000's Avatar
ninerM1000
Thanks. That looks way cleaner with the single block in the back.
Old Jun 2, 2011 | 10:25 AM
hav24wheel's Avatar
hav24wheel
The third u bolt has nothing to do with the lift kit.............. Its for the air bags.... Kinda a odd setup, but still.
