5.4l Keeps killing Coil Packs! Need help!
#31
#32
#33
Its highly ill-advised to suggest testing these the old school way but I'll describe it anyway. Remove COP from plug leaving boot, contact spring and wiring harness connector intact. Hold the COP with an insulated plier etc close to a grounding point and crank the engine. If the coil is good it will throw a spark--if not then something is wrong.
Before COP's this sort of test would give a fair indication if energy was being delivered to the plug.
Wakeon also makes an inductive detection device that can be used to test COP's merely by touching a pad to the top of the COP case. Almost bought one for new cheap but because this is a rather rear situation it didn't seem like a tool I really needed.
Not that there's anything wrong with owning tools not needed constantly right?
#35
#36
#37
I am having coil problems as well. I bought Accel and got 18,000 miles out of them before they started going crazy. i spoke with my local Ford dealer mechanic and he said he has never seen a coil pac except the OEM last any length of time. Tomorrow I am biting the bullet and buying OEM. I can't pull my work trailer on 6 cylinders and sputtering. I used some of the Grantelli products on a 2004 H2 Hummer and only caused problems. Even with lifetime warranty , enough is enough.
#38
#40
Went by the local Ford Dealer on Monday and picked up 8 OEM coil packs at $76 each. An hour later, all my problems are gone. Today I pulled my 8000 pound JD backhoe and worked the engine pretty hard. Before the coil pack change , I would get a over fueling code, its gone too. I wish I had not wasted my money on the "yellow " coils,
#41
More often than with any other brand Accel COP's are reported to have issues, typically a short time after being put into service.
That's not to say many aren't in use and working just fine but we rarely hear of repeated problems with the brands we've all learned are better over the longer term. Sure they're more expensive but what does reliability and dependability matter to us? If so I'll pay the extra and not have to "hope" everything will be fine and dandy.
#42
#43
The threaded insert that the COP hold-down bolt threads into is spinning inside its casting. My V10 did that to me a couple of years ago.
Had to drill the bolt head off, then drilled out the insert and old screw at one pass, then re-threaded with the next larger bolt size. Now, one COP has a larger diameter bolt and larger head but it works.
#44
Scottt Bealss
1999 to 2016 Super Duty
16
05-12-2017 06:19 AM
thegreatgate
1997 - 2003 F150
03-21-2016 04:57 PM
V8SHO
1997-2006 Expedition & Navigator
30
03-16-2016 10:10 PM
