Battery Time ?
Old May 30, 2011 | 01:02 PM
High Binder's Avatar
High Binder
Battery Time ?
Hey guys, my truck has had the same two batteries since Oct '07 (well that's what's stamped on the batteries so..) Anyhow, my lack of driving this truck has probably killed them, I have to keep throwing a charger on them. So what does everyone like for new batts? I want to maximize CCA (cold cranking amps).
I also plan on putting a trickle charger on them so they don't eat it...
Thanks!
Old May 30, 2011 | 01:46 PM
zhilton's Avatar
zhilton
I bought a pair of Motorcraft 850CCA from my local dealership last fall for $250, for the pair. The reason I went with those....100 month warranty (36 month replacement), free roadside assistance for the first 36 months and any Ford/Lincoln/Merc dealership will honor the warranty. I do allot of traveling for work, so like the tires from Sam's under the truck...it just made allot of since for me. The only drawback, the dealership has to install them for the warranty to be honored.
Old May 30, 2011 | 05:17 PM
Nice Work Truck's Avatar
Nice Work Truck
I put two Sears Platinum batts in and they are great.
They are 930 cca and a 100 month warranty and 48 month replacement.
My truck has never started so good.
They are just pricey and about $200 each.
Old May 30, 2011 | 05:46 PM
Krump's brother's Avatar
Krump's brother
Battery Tender Twin 800 - USA & Western Hemisphere - Automotive - Batterytender.com
Is that what you plan on using? I've heard good things about them, but never really needed one.
Also, I went with the Sears batteries, too. They weren't cheap, but after two years they still got me through another NH winter without plugging in-the T6 probably helped.
Old May 30, 2011 | 05:51 PM
bismic's Avatar
bismic
My Motorcraft 850's are working just fine, but when the time comes again, these will be my choice.
Old May 30, 2011 | 06:33 PM
wulfman's Avatar
wulfman
Hey HB i have two Bosh batteries 1000 ca been great got them from pepboys, had them for two years now, but they just replaced one free both would not to both, passenger side went bad
Old May 30, 2011 | 06:46 PM
69cj's Avatar
69cj
If you know what a favotite oil post is? Give this another 48 hours and it will be 10 pages long.
Old May 30, 2011 | 07:28 PM
sandmanf250's Avatar
sandmanf250
batts
my stock 750 cc's in my 03 6.0 went7years and were still working good,but i knew the ficm needs good juice so got another pair of motocraft 850's.no problems in 199,650 miles,just an icp sensor.
Old May 30, 2011 | 07:55 PM
High Binder
Originally Posted by Krump's brother
That's exactly what I'm planing on using. I already have one that I use on my bikes but will get another just for this! They are awesome especially if you wire in some leads for a quick connect.
Old May 30, 2011 | 07:59 PM
High Binder
Yeah, that maybe the case but there's a ton of good and valuable info in those 10 pages so I think it's worth it.
P.S. I rep'ed everyone who responded so far. Zil and Mark I 'have to spread it around more" but reps coming.
Old May 30, 2011 | 08:24 PM
zhilton's Avatar
zhilton
Yip, aren't they fun! I forgot to mention in my first post that the batteries that came out of my truck last November where the ones installed by KTP back in 9/03. I figure 7 years was long enough on a set of batteries...especially with the number of FICM failures everyone was having the winter of '09/'10. I took one of the batteries and stuck in it the Explorer and still fires right up fine (the Explorer doesn't get far from the house much anymore).
