59 4x4 that doesn't work whats wrong
Old 03-25-2003, 12:51 AM
CHRISBell707's Avatar
CHRISBell707
CHRISBell707 is offline
Question 59 4x4 that doesn't work whats wrong
I have just purchesed a 59' Ford f100 4x4 and I was out with a group of friends 4wheeling and I got stuck in some mud. I thought I was in 4 low trying to get out but the front wheels weren't spinning. After some shoving and swearing, I decided to try it in 4 high and was able to get out with no problem. I got home the next day and tried to shift it in 4 low without the hubs engaged to see if the front drive shaft was spinning, and it was not. What do you think my problem could be?
Old 03-25-2003, 10:21 PM
alpo23's Avatar
alpo23
alpo23 is offline
with the stock shifter the rear output ingages before the front output in 4-low. Have someone sit in the drivers seat and push the shifter to 4-low while you climb under neath and slowly turn the front drive shaft. you need to make absolutly sure that the front gear slider in the t-case is moving fully into possition. by spining the drive shaft you assure that the slider is not hanging up on a tooth preventing it from engaging.
If it is moving fully, then drain the oil out and pull the PTO/access cover on the DANA 24 t-case and inpsect the internals while engaging the shifters.
Eric
mikepo
28
05-23-2016 01:07 AM
Larry00663
1999 to 2016 Super Duty
03-15-2016 09:29 PM
slomafarms
1997 - 2003 F150
12-23-2015 06:58 PM
Misterunlimited
1997 - 2003 F150
10-01-2015 12:54 PM
heebeha
03-16-2015 02:20 PM
Quick Reply: 59 4x4 that doesn't work whats wrong
