88 F350 rear tank removed in place of a bronco 33g. Sending unit wiring on bronco has 2 14g wires and different colors then F350 19g tank, all 18g wires. Have to splice sendin unit connector. Do i reconnect according to pin locations or colors ? Only 2 colors are the same for both connectors
both tanks are 88-91's. the notches on the sides of the connectors are a little different, and the f350 wont fit the bronco sender
I was hoping you were online bill
i see i have a 90+ bronco tank an sender. I'll have to order an 88 new
Bill, thx for you're help, i knew you'd come thru for me. I really appreciate it
