Coolant Change?
Old May 28, 2011 | 10:40 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Coolant Change?
When I bought my truck a few guys on here told me to change my coolant. I never really thought anything of it, but now I'm thinking I should ask more.
I noticed its not as easy as my old F150 where I could just add some prestone.
I believe there are different types of coolants and additives and such. Basically I have not touched the cooling system since I bought the truck. Is there a way to check to see if I should change it, and if I should what are the steps? Is it just like on my F150?
Old May 28, 2011 | 10:55 PM
cj45lc's Avatar
cj45lc
You can do a search for Gooch coolant flush & it's full of good info on the different coolants. Seems like most go with the ELC so you don't have to worry with the SCA additive that needs to be checked with test strips regularly
Old May 28, 2011 | 11:06 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Thanks thats what I was looking for.
Old May 29, 2011 | 12:40 AM
clintbonnie's Avatar
clintbonnie
Here is link for more coolant flushing info, etc...
https://www.ford-trucks.com/forums/9...formation.html
Old May 30, 2011 | 06:21 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
Well I just realized I'm about an inch below my cold fill line. So I'll try to get to it this week or the weekend.
Old May 30, 2011 | 06:32 PM
ToMang07's Avatar
ToMang07
I'm planning on doing mine the soon as I get the money together for a bypass filter.
http://www.dieselsite.com/index.asp?PageAction=VIEWPROD&ProdID=8
Hopefully this week, gonna go with CAT ELC, and do the full flush/wash/rinse, fill up with the ELC, and as long as everything is kosher, in with the bypass filter!
Old May 30, 2011 | 06:36 PM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
I plan on a full flush also. But I just found a problem elsewhere in the engine compartment that needs immediate fixing, so that is coming first. (see new thread called Routine Engine Compartment Check...)
FordArizonaF150
2009 - 2014 F150
May 16, 2013 09:37 PM
31vikes
May 12, 2011 05:35 PM
Phil Schroder
Dec 14, 2006 08:26 PM
01' Super Crew
1997 - 2003 F150
Mar 6, 2003 09:26 PM
