2000 Ranger 3.0 issues
Old May 28, 2011 | 09:08 PM
maverickman514's Avatar
maverickman514
2000 3.0L Ranger having problems....
about 3 months ago I replaced the timing set and water pump and seals.. put it back together and everything worked great... until yesterday...
Driving home, came to a stop sign, and suddenly it had a MAJOR LOSS OF POWER... started running rough and could barely pull itself the last 1/2 mile home...
when it does start, it idles very rough and the settles down if you feather into the throttle. (in PARK-- not sure about under load)
I unplugged the TPS and it would start and idle a bit easier..... without having to give it any additional throttle...
REPLACED TPS and now it will not start at all... any ideas? was the TPS even a likely culprit afterall?
PLEASE HELP
and THANK YOU ALL IN ADVANCE
Old May 28, 2011 | 10:03 PM
Rockledge's Avatar
Rockledge
Did the CEL come on? I wonder if there are any pending codes.
Unless you get a code saying otherwise, then I doubt it's a TPS issue. I've never heard of them failing so suddenly.
Not a lot to go on, but If I had to make a preliminary guess, I'd go with some sort of fuel-delivery problem. A fuel pressure check would help with the diagnosis, in any case.
Old May 28, 2011 | 10:08 PM
maverickman514
I need to actually put a pressure gauge on it, but in a pinch last night, I just stuck a screwdriver in the schrader valve, and got a pretty good shot of pressurized fuel spray.... a friend's truck and it was late, so we checked it out real quick..... will do more thourough check this weekend.
Old May 28, 2011 | 10:22 PM
Rockledge's Avatar
Rockledge
That does seem to indicate fuel is present at the rail.
Regarding the fuel pressure test, keep in mind 1998+ Rangers utilize what is known as a "mechanical returnless" fuel system which has the following characteristics:
(1) there is no return line running back to the fuel tank from the fuel rail;
(2) designed to operate at higher fuel pressure- specs are 64psi at all times when pump is on (+/-8psi);
(3) the fuel pressure regulator is now in the fuel tank with the pump, not on the fuel rail.
87-XL-Squared
Feb 26, 2016 07:52 AM
87f250banks
19
Apr 2, 2011 10:03 AM
Clint.d
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
May 30, 2009 12:59 PM
mgmoynihan
Aug 25, 2007 04:04 PM
volfan945
3.0L V6
Sep 28, 2004 08:56 AM
