Hesitation
Old May 28, 2011 | 08:51 PM
rcosta's Avatar
rcosta
Hesitation
Hi, I have a 2000 ex that recently has been hesitating while idle and then again somewhere between 40 and 50 mph. Otherwise it runs fine. I keep adding gas thinking maybe I had bad gas but it remains consistant. Any places you would check? Thanks.
Old May 28, 2011 | 08:56 PM
jh818's Avatar
jh818
Does it sound like a misfire? When were the spark plugs/boots replaced? Was it raining when it started?
See if you can get codes read and start from there.
Good luck.
Old May 28, 2011 | 09:07 PM
rcosta's Avatar
rcosta
Can you recommend a good code reader? I am new to this.
Not sure what a misfire sounds/or feels like. But I was thinking about the plugs. I have only had it a few months and have no idea when they were replaced. Thanks.
Old May 28, 2011 | 09:15 PM
jh818's Avatar
jh818
I have Scangauge II that is always hooked up. I use it to monitor my trans temp. It also has a code reader. It plugs right into your OBDII plug just below your steering wheel.
If you don't know when the plugs were changed when you bought it and it is around the 100K miles mark, then I would go ahead and replace them along with the rubber boots since you will eventually need to do it. Who knows, by changing the plugs and boots, it could resolve your hesitation issue...maybe.
Old May 28, 2011 | 09:17 PM
jh818's Avatar
jh818
You could take it to an auto parts store like Autozone or O'Reily's and they can read it for you.
Old May 28, 2011 | 09:19 PM
rcosta's Avatar
rcosta
Thanks
I will give the change a shot. Thanks as always.
socal00
Feb 19, 2010 01:46 PM
2kmelat
6.4L Power Stroke Diesel
Aug 27, 2009 06:52 AM
Trakk
18
Dec 10, 2007 07:31 PM
62stepside
Aug 15, 2002 11:35 AM
