kickdown linkage
Old May 28, 2011 | 08:09 PM
jml72's Avatar
jml72
kickdown linkage
Just installed a edelbrock carb on my 79 F150 - 460 with a c6, need pictures of set up of throttle set up and kickdown
Thanks
Old May 28, 2011 | 09:36 PM
trap4x4's Avatar
trap4x4
I switched out to a Holley b/c i couldnt get the linkage right - even w/ edel's add ons ....
Old set up ....
Old May 28, 2011 | 10:55 PM
grinnergetter's Avatar
grinnergetter
I had to customize the linkage and throttle rod(73). So far ...so good.
Old May 28, 2011 | 11:34 PM
hp246's Avatar
hp246
Lokar........................
Old May 28, 2011 | 11:39 PM
tbear853's Avatar
tbear853
I added a extension on the factory linkage to mate wit the Ford kickdown part of the Edelbrock carb.
Had wife mash it to floor and checked to make sure aCarb was WFO, then while she held it down, I moved truck's kickdown as far back as possible. Measure difference, made extension that long and simply bolted it to the Ford link.
Fine adjust with screw.
Old Feb 25, 2017 | 01:40 PM
'77 F100 Custom's Avatar
'77 F100 Custom
I know this is an old thread, but what is the Edelbrock part # for the kickdown linkage? Doing a 429/C6 with Performer intake, and a 1407 Eddie carb. Thanks.
Old Feb 25, 2017 | 01:48 PM
'77 F100 Custom
Ok, #1483. Is this the only piece I will need to connect my kickdown rod.
Old Feb 25, 2017 | 10:53 PM
PapaBearYuma's Avatar
PapaBearYuma
That should be all you need. I installed a 1411 on a 77 460/C6 last week, using the 1483 linkage, and it all went together nicely.
Old Feb 25, 2017 | 10:56 PM
PapaBearYuma
Old set up ....
I thought that bar off the corner was a pretty poor design, but I bent it up, so the spring clears the linkage, and it works fine on mine
Old Feb 26, 2017 | 09:55 AM
beartracks's Avatar
beartracks
Anyone using the Lokar on a Speed Demon/C6? The carb has a ball/lever but doesn't reach the rod. Might try bending it.
Henshaw
Oct 25, 2018 07:35 PM
thedopefishlives
Mar 17, 2017 05:31 PM
jwcopeland
Jan 25, 2017 06:41 PM
Building_Fords
Sep 5, 2016 09:24 PM
schoo
Apr 2, 2016 09:59 AM
