new pump and sending unit
Old May 28, 2011 | 05:36 PM
kenpobuck's Avatar
kenpobuck
The old high pressure intank pump finally gave up on my baby. Since the sender was bad as well I decided to buy a new low pressure intank pump and sender for her and do away with the bypass pressure regulator I have been running. Well the pump does great but the gauge still don't work! I checked the sender and it works fine (should it is new). I also checked the gauge by grounding the wire and it jumps straight to full so it should also be good. Now for the big question. What are the ohms for the diesel sender in a 86 F250? The gasser sender is 15 empty and 164 full.
Old May 29, 2011 | 05:18 PM
PLC7.3's Avatar
PLC7.3
This info is from the 93 manual but it's all I have.....
Here are the fuel guage test #s
22 ohms sent to the guage it reads empty "E"
145 ohm sent to the guage it reads full "F"
Here are the sender test #s
Sender at empty stop 14-18 ohms
Sender at full stop 154-162 ohms
Old May 29, 2011 | 06:04 PM
kenpobuck's Avatar
kenpobuck
Thanks, it all seems to be in order but don't function lol. Guess I will mess with it some more.
wcerqua
Feb 20, 2012 07:11 PM
carlsson
Feb 20, 2012 05:14 AM
T Tom
1978 - 1996 Big Bronco
Jun 2, 2010 04:47 AM
1975StroppeBaja
Jan 12, 2009 02:45 PM
rocky92f350
Jul 8, 2002 10:31 AM
