C-6 front seal
Old May 28, 2011 | 04:16 PM
Yardpilot's Avatar
Yardpilot
C-6 front seal
!973 F-100. Originally a 240-6 standard, now a 351 Cleveland 4V with a C-6. Everything is a bit odd on this truck. I need to replace the front trans seal. I'm an old fart working in the driveway. It's up on four ramps. Can I do this by separating the trans from the engine? Do I need to pull the trans? Can I do that without a transmission jack? Anything to look out for besides my own quirkiness? I'll be fabbing a new cross-member to replace the funky car one the guys jammed in there when they did this. 2 inch square .125 inch mild steel with trimmed angle iron mounts. Between the rails or below? Thanks for any help.
Yardpilot
Old May 28, 2011 | 07:17 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You'll need to drop the tranny, doubt you'll get enough clearance to slide the trans back to remove the torque convertor to get to the pump and seal.
I recommend replacing the pump o-ring and gasket along with the input seal.
Josh
Old Jul 17, 2011 | 11:13 PM
Yardpilot's Avatar
Yardpilot
Thanks. I yarded it out and found fun things. The front seal was bad, all right. So was the bushing. Chewed to shreds. That may have been because it was both in backwards and 90 degrees off from where the book says it should be. New bushing, new seal, new o-ring, new gasket, new bolts to that point. I extended the wires so I can plug them together up higher for access. The old ones were a bit goofy and bad anyway. If all goes right (yeah,sure) I may have it back in there in a day or so.
