Hi
I have five carbs, and when ordering a new rebuild kit I found the numbers on the body not all mach each other, different years I guess.
My question is how can I identify them to know what they were for?
and what rebuild kit are for wich carb
Thanks
Hi
Thanks
The 1904 was considered an Economizer Carb and the casting numbers on the Main body identified which model it was of which there were many of the 1900 series. There's more info' here on this site to help you find the parts you might need- Holley 1900 1V Tech Info - The Carburetor Doctor
Good luck with the rebuild. They can be a pain. You should Google "Holley 1904 rebuild". You'll find a great "how to" article posted on the IHC forum, as Internationals and Studebakers used the Holley 1904 carbs. There were also plenty of discussion about them on FTE sometime last year.
I had about nine of them. Took them all in to a local rebuilder. He was able to pick out two decent carbs out of the nine that I gave him to rebuild. One of the issues with the Holley 1904 carbs is that they warp around the bowl cover from being overtightened. They will leak from the bottom of that area. My rebuilder had to straighten those areas slightly and then hand-make the gasket for the bowl. I also got a one year warranty and each carb cost me $130 to rebuild.
Also, some Holley 1904 are actually Holley 1960. Both look alike. The other thing to consider are the jets. Depending on the year of the vehicle and the engine, the carb had different jets. If you don't have the correct size jets in your carb for your engine type, you may be starving or flooding the carb.
Check your main well(large valve body inside of fuel bowl) for cleanliness and the economizer valve for proper movement, be very meticulous, these carbs(1904/1960) don't need much out of whack to not work correctly.
As Ilya said, go on to IHON.com and find Michael Mayben, he knows these carbs down to the science. But his rebuilds aren't cheap, so at least try it yourself first and make sure EVERYTHING is in working order. The main wells on these things love to crap out on people, and are sometimes already tampered with and in poor condition.
I have found these to be easy to rebuild. The only additional warning I would add is to reuse the original needle and seat. The replacement seats I have seen have a through hole that is twice the size as the original and cause carburetor flooding after a short time. I also don't like the new viton tipped needles as these develop a groove where they seat and then don't seal.
Remanufactured 1904 carbs are available.....been thinking about trying one. I've got a half dozen old junkers, none seem to work right.
From what I've heard, not experienced is that those are crap. The rebuilds on those are terrible quality and often overlook the typical issues of these carbs.
I can't say I've had either of these issues. I had flooding on one rebuild I did, and as soon as I reset the float to the spec it was fine.
Here are my Holley 1904s after a rebuild.
I know this is an old post, but cant help saying your engine and carbs look great! I came upon the thread while looking for a source of rebuild kits for a 1904. It has been quite a while ago, but I think my former 1954 F350 with I-6
used a 1904.
Thanks, but a few weeks later the engine developed a mysterious and enormous backfire that I wasn't able to resolve successfully. The engine is currently in pieces at the machine shop.
