engine stumbles at idle
Old May 28, 2011 | 12:33 PM
gfmk's Avatar
gfmk
Hello guys. I just changed my fuel and oil filters and now i get a rough idle of and on.It is driving me crazy.Any ideas please
Old May 28, 2011 | 01:25 PM
sarnott140's Avatar
sarnott140
did you use OEM filters?
Old May 28, 2011 | 01:29 PM
gfmk's Avatar
gfmk
stumble
No I used wix. Is that an issue? thanks
Old May 28, 2011 | 01:40 PM
sarnott140's Avatar
sarnott140
yes very much an issue, do some searching and you'll see why. swap them out with some motorcraft filters and I bet the rough running issue will be gone.
Old May 28, 2011 | 01:45 PM
gfmk's Avatar
gfmk
stumble
Will do it.I pulled code p0269 also.Is that something to worry about.thanks
Old May 28, 2011 | 03:09 PM
bismic's Avatar
bismic
That is a cylinder contribution code for #3 cylinder. It could indicate an injector issue.
Get the proper fuel filter installed and then I would highly recommend a fuel pressure gauge.
Old May 28, 2011 | 03:20 PM
gfmk's Avatar
gfmk
fuel pressures are all good on all injectors? i have an auto enginiuity scanner
Old May 28, 2011 | 03:31 PM
bismic's Avatar
bismic
The autoenginuity can not read fuel pressure - there is no Ford sending unit.
Old May 28, 2011 | 04:00 PM
gfmk's Avatar
gfmk
ok then tell me what i need to do then.I am having fun .....thanks
Old May 28, 2011 | 04:58 PM
bismic's Avatar
bismic
Google
firedaniel
Aug 6, 2013 08:38 PM
79bigblock
Nov 18, 2010 10:28 AM
crescentwrencher
Apr 4, 2008 08:37 PM
Bert2
1983 - 2012 Ranger & B-Series
Jun 11, 2004 08:54 PM
rerun123
17
May 12, 2003 01:54 PM
