I want to change spark plugs on my 2003 Ford Ranger, 4.0 SOHC truck. Plugs on the drivers side can easily be reached, but those on the passenger side are a real challenge. Any suggestions on how to reach those tough ones will be greatly appreciated.
This is what i do. Ill drop the socket in the hole of the spark plug then ill use my finger to get the socket on the plug, then put ur extension on the socket then put the wrench on the extension, Then when its loose take them all off in the opposite order and use ur fingers to get the plug out, or some little pliers, or a magnet, It may sound confusing but once u give it a try ull get what im saying
