Help!
Old May 27, 2011 | 06:08 PM
altitudejunkie's Avatar
altitudejunkie
Help!
How do I pull rear axle on F-100? is it really just four bolts? isnt there a clip or pin inside Pumpkin? Appreciate a quick reponse, am in it right now.
Old May 27, 2011 | 07:18 PM
HIO Silver's Avatar
HIO Silver
BAM! The end plates hold the axles to the housing... four bolt and nuts on each side. Reach through the axle flange to undo. No C-clips... thank goodness.
Old May 27, 2011 | 07:25 PM
altitudejunkie
Thanks! I ended up sliding the drum on to the lug bolts backwards, threading the nuts on partways and, as you said,Bam! used the brake drum as a slide hammer and pulled the axle out through the remnents of the bearing- slicker'n-snot!
have a good one!
