59 F100
Old 05-27-2011, 03:22 PM
leewiffen's Avatar
leewiffen
leewiffen is offline
59 F100
Well...it looks like I've solved some questions regarding authenticity thanks to numberdummy but now the fun begins.....how to make my new truck daily usable in the UK.
I have bought this 59 F100 with a 351W fitted on a C4 transmission. Now when it gets here I think I will need to uprate the brakes from drum to discs as well as fitting some power steering.
Firstly can anyone recommend how I can do this without resorting to "clipping". Also would you fellas recommend any other modifications to make it an easy driver for an old fat bloke? Rear axle...I don't want to change the ride height...it's a Styleside body...ver pretty.
Oh and how about the fuel tank being behind the seat...do I need to and can I resite the new tank in between the chassis and if so, what tank should I use.
A/C....am I being too ambitious?
Awaiting the wisdom !
Old 05-27-2011, 11:26 PM
tinman52's Avatar
tinman52
tinman52 is offline
Welder User
Some good reading here, links in the first post....
https://www.ford-trucks.com/forums/1...s-how-tos.html
Disk brake kits are available from several vendors.......Google.....
Power steering can be had by fitting a Toyota power box or similar.......
Gas tank.....should be a current thread running.....basic idea applies to all models.
Old 05-28-2011, 12:00 AM
ben73058's Avatar
ben73058
ben73058 is offline
Hey Lee,
The gas tank re-location is a good one - Nice weekend project with a high success rate - nice one to start with. You can do a search on this site for it & you should see multiple examples with pictures. The most common tanks used are 68, 69,70 mustang tanks. They fit in between the rails out back - you have to move one of the bed supports & do a little bracket welding. I personally used a 1970 mustang/cougar tank because it was 22 gallons & I wanted the extra range vs. the 16 &18 gallon tanks from earlier years.
It's easier to do with the bed off the truck. You also need to patch up the hole left in the side of the cab for the fill cap. The new fill location will be in your bed unless you get excited & do it out to one of the fenders.
Good luck over there.
Ben in Austin
(The article by jniolin is very good about relocating tanks).
Old 05-28-2011, 06:58 AM
Walston's Avatar
Walston
Walston is offline
To make my 60 more drivable and safe we did the following modifications:
Front Disc Brakes, I got the kit from ECI Brakes and I used a power booster from a 1973 F-100.
Power steering, we did the Toyoto conversion. The attached link is a technical article on it. Toyota Steering Box Swap For 1948-1960 Trucks .: Articles
Moved the gas tank to where the spare tire was originally installed. We used a 1969 mustang tank.
Upgraded the wiper motor to a ranger motor take make them more reliable and to have intermittent wipers.
There are pictures in my gallery, click on my name and select gallery.
We also added AC, These 2 links tell about the installation: https://www.ford-trucks.com/forums/7...lternator.html
https://www.ford-trucks.com/forums/7...-part-2-a.html
I would also recommend installing a new wiring harness, we used Easy Wire.
Good luck.
Old 05-28-2011, 08:07 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
I get a kick oughtta y'all installing the tank where the spare tire is. Guess y'all don't recall the exploding Pinto fuel tank fiasco of the 1970's. 100's of peeps were burned to death/maimed for life.
Just like the Pinto's, you have no protection when rear ended...the gas tank will hit the rear axle, split open at the seams, fuel will spill out...guess what happens next?
How many in-cab tanks split open when the trucks were T-boned? I'm not aware of any. The tank is situated high in the cab for a reason.
Old 05-28-2011, 08:48 AM
ben73058's Avatar
ben73058
ben73058 is offline
Numberdummy,
Where is your tank in your 2011? It's out back under the bed - Why do you suppose they moved it there?
I moved mine because it bothered me a lot to sit with 16 gallons of gas -
it sloshed around & whenever I filled up it stank to high heaven in the cab.
It's more personal choice - it dramatically improved the quality experience of driving around & it isn't that difficult to do. I recommend it highly.
Ben in Austin
Old 05-28-2011, 10:56 AM
52 Merc's Avatar
52 Merc
52 Merc is offline
Received 2,514 Likes on 1,432 Posts
Apparently you don't remember the reason why the tank was removed from the cab in the 70's, as well. Same issue, different way it happened. It seems with their higher center of gravity, trucks were prone to tip on their side in a T-bone collision. If tipped on the filler neck side, the fuel would come pouring out and catch fire, and 100's of peeps were burned to death/maimed for life.
http://www.serna-associates.com/news...older-pickups/
The fact of the matter is fires in collisions are rare. Unless you're on Dateline/NBC.
Old 05-28-2011, 04:48 PM
Walston's Avatar
Walston
Walston is offline
Life is full of risk management decisions. I prefer not having the tank in the cab, others may chose differently. No location is perfect.
Old 05-28-2011, 08:09 PM
kenjh's Avatar
kenjh
kenjh is offline
just my 2 cent's worth ..when I took my truck out for her maiden run ..I had a marine gas can on the floor in the cab..worked fine..but then as you say 'God protects fools and little kids... '
BigSix1
08-17-2014 07:13 PM
AstroFab
18
02-05-2011 07:23 PM
LipschitzWrath
08-16-2010 01:29 PM
blankcollar
10-18-2006 09:22 PM
1979_F100_302
Engine Swaps
03-29-2004 10:10 AM
Quick Reply: 59 F100
