Pollak switching valve install
Old May 26, 2011 | 08:35 PM
GAFDM's Avatar
GAFDM
It looks like I will replace my bad Ford valve with the Pollak. Question-- do the nylon lines slide on and then the retainer clip slides in or is this a hose and clamp setup? I have not purchased the valve yet.
Old May 27, 2011 | 08:14 AM
subford's Avatar
subford
Yes the lines slide on and then the retainer clip slides in.
But Pollak does not make a selector valve for your truck unless it is a Diesel or you have a 460 with a Carb.
Old May 27, 2011 | 08:44 AM
GAFDM's Avatar
GAFDM
I have a 460 with a carb. The pictures I see on the net show what seems to be a hose and clamp fitting, is there a unit specific to the nylon lines with the push on fittings and clips ? Thanks
ligito
Apr 12, 2015 09:38 PM
Rubiconrod
All Things Towing
Aug 15, 2014 11:33 AM
casonamson
17
Nov 17, 2013 09:06 AM
devolution
15
Jul 13, 2013 11:50 PM
