Crank pulley removal
Old May 26, 2011 | 10:41 AM
way2fast1's Avatar
way2fast1
I have Been trying To remove the Crank pulley from my flatty with no luck! I have tried a 7 ton gear puller with no luck just bends the pulley, I have tried heating it up as well. I am not worried about damaging the pully as all I need is the crank. But I would like to know the correct way so when I pull the one I plan on reusing, it will be straight.
Old May 26, 2011 | 10:35 PM
mtflat's Avatar
mtflat
There is only the bolt on the end of the crank snout that keeps it in place. It has a keyway that keeps it from turning, but otherwise it just slides on the shaft. Heat, lube and maybe a prybar against the crank end of the pulley.
Drop the oil pan and the timing gear cover and you should be able to get behind it.
Old May 26, 2011 | 11:32 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Don't be shy with the hot wrench, get it good and warm all the way around.
Old May 27, 2011 | 09:06 AM
way2fast1's Avatar
way2fast1
Guess it's time to break out the rosebud!
Old May 27, 2011 | 10:27 AM
ALBUQ F-1's Avatar
ALBUQ F-1
You want to heat it fast, before the crank can absorb heat and start to expand (maybe this is obvious, but...)
Old May 28, 2011 | 10:51 PM
way2fast1's Avatar
way2fast1
Amazing what can be accomplished with the proper application of the hot wrench, sledge!
Old May 28, 2011 | 11:09 PM
ALBUQ F-1's Avatar
ALBUQ F-1
Congrats! The penetrating oil doesn't seem to have made it deep in there? That usually is the case.
Old May 28, 2011 | 11:18 PM
tinman52's Avatar
tinman52
Welder User
Wow, never seen one rusted on that bad......at least you got it off!
Old May 28, 2011 | 11:37 PM
52 Merc's Avatar
52 Merc
That's all fine and good, but what if your plan is to reuse the pulley??? That one looks to be down for the count.
Old May 28, 2011 | 11:44 PM
way2fast1's Avatar
way2fast1
That pulley was already damaged, I have another one on my broken crank that is good. So the real challenge will be removing that one without damage.
Old May 29, 2011 | 12:10 AM
52 Merc's Avatar
52 Merc
If you figure out the trick, let me know. I'm still scratching my head on this one. I'm used to balancers with bolt holes in them. ;-)
ripstar1
1997 - 2003 F150
13
Mar 3, 2014 09:48 PM
fordf350camper
Nov 14, 2012 09:46 AM
Heater51
Sep 6, 2012 08:10 PM
78sharpshooter
Jun 21, 2007 12:29 AM
cableguy815
Aerostar
Aug 18, 2003 08:50 AM
