EOT >260
Old Jun 18, 2011 | 01:14 PM
BLADE35's Avatar
BLADE35
Originally Posted by ddcattleco
Forgot to mention, he's 1.5 hours away on his way back. At what temp does he need to shut it down?
at 260 eot sounds like its starting to defuel since it runs ruff
does the BPD oil cooler have a thermistate in it somewhere
sounds like it started going downhill after the BPD oil cooler was installed
Old Jun 18, 2011 | 03:54 PM
ddcattleco's Avatar
ddcattleco
Since I have the Bulletproof, at what temp should I get concerned? Also, I was reading a post elsewhere and they were saying the thermostat should be kicking in and not letting the coolant temp be getting over 200. Is that right?
Thanks
Old Jun 18, 2011 | 03:57 PM
bismic's Avatar
bismic
The thermostat is not designed to be fully open until 215 or so.
Old Jun 19, 2011 | 10:35 PM
el boricua's Avatar
el boricua
The scangauge have at least that I know two configuration settings for the EOT gauge. To verify that your EOT readings are accurate wait overnight for the engine to cooldown. At that point ECT and EOT should be at the same temp. If your EOT is for example 50 degrees hotter than your ECT. Your EOT settings on the Scangauge are not right. It happend to me when I had my 06.
You have to be sure that those high EOT that you are seeing are really that hot.
I was a Ford guy. I have owned about 7 different ford truck between Broncos, F-150's and F250's. But that 06 Superduty was a PITA. And the drop that fill my cup was my "stealership" witch I have to almost tell step by step how to deal with my engine because of their lack of knowledge.
Old Jun 20, 2011 | 11:48 PM
Young Gun's Avatar
Young Gun
Maybe i read it wrong but it sounds to me like the stock oil cooler caused the problems,
Old Jun 21, 2011 | 04:54 AM
npccpartsman's Avatar
npccpartsman
Thanks
Did you actually replace the factory cooler with a kit like this: http://www.bulletproofdiesel.com/Pho...tCode=90402001 Or did you just replace the factory oil cooler with a factory oil cooler from bulletproof and maybe a bulletproof EGR cooler?
If you have a full bulletproof oil cooler setup like the one in the link I posted, depending on what you purchased, it may or may not have a thermostat on it. This kit shows the full cold weather package added. Regardless, I wouldn't think it should get that hot or have that much temperature difference between the two.
ryobi1
Sep 21, 2016 01:30 PM
amsk8er1983
Sep 5, 2016 04:39 PM
FiveOJester
Dec 1, 2015 01:36 PM
f150crewcab
Jun 4, 2012 07:41 PM
WhiteBeast-05-powers
Sep 16, 2011 07:18 PM
