48K relatively trouble-free miles have caused me to be in denial about the potential size of this illness that has developed in my '01 Limited 4X4 Excursion. I noticed an air leak noise in the passenger-side rear wheel well 2 days ago. Found that the noise is coming from the top of 4 aluminum lines with plastic sheathing around them. There is also a green fluid leaking from this line (not coolant). The air-leak noise IS STILL THERE. It is clear that the line has finally sprung this leak after constantly rubbing against the steel shackle that houses the leaf springs. Is this a common problem? What are the repair options? Thanks!
