NOW THIS!!! DIED, SKIPPING
Old May 25, 2011 | 05:49 PM
dj211's Avatar
dj211
just got my truck running a few days ago, found out it was a faulty ICP. Today i warmed my truck up like normal, ran fine for 5 min then it just died! thinking it was no big deal i started it back up and everything seemed fine. Driving down the road for about 3min it started to skip about every 5min or so. and from what i can see it does it when i hold my throttle steady. PLEASE HELP!
i just replace last week my idm, cps, tps and peddle assembly. thinking these were the problem for my last issue. should i put my old cps back in considering its fine?
Old May 25, 2011 | 06:12 PM
MX_Fyrcaptain's Avatar
MX_Fyrcaptain
Sounds like it could be the UVCH, but someone smarter than me will chime in soon.
Old May 25, 2011 | 06:14 PM
dj211's Avatar
dj211
thanks for the quick respond. unfortunetly that was the first thing i tried with my last issue i had.
Old May 25, 2011 | 06:36 PM
clintbonnie's Avatar
clintbonnie
Did you check the center pin on the UVCH connector for being burnt ? Do you get a CEL when it skips.. Have you read your fault codes ?
Old May 25, 2011 | 08:35 PM
dj211's Avatar
dj211
uvch looked fine. all wires were in good condition. and yes my service engine light came on and stayed on after about the 3rd skip.
Old May 25, 2011 | 08:38 PM
dlibson's Avatar
dlibson
Well did you read the codes?
Old May 25, 2011 | 08:52 PM
badhabit1's Avatar
badhabit1
Could be the IPR (injector pressure regulator). These sometimes get stuck or dirty and cause the exact same symptoms as a bad cps. Sometimes it is just the orings around the IPR. The IPR controls pressure to injectors via the signal from the ICP. Sometimes unplugging the ICP will temporarily "unstick" a stuck IPR.
Old May 25, 2011 | 09:01 PM
dj211's Avatar
dj211
yup. the codes that were read were just soft code. one for my tuner and one for my ebpcv delete (i have a banks power elbow). so all the codes are reading fine. i did replace the cps with my old one and it looks like its working. but if not i will try the ipr
Old May 25, 2011 | 09:12 PM
dlibson's Avatar
dlibson
Can you look at data or just codes? I'd be curious as to what your HPOP pressure is. IPR could be too.
Old May 25, 2011 | 09:17 PM
clintbonnie
What kind of scanner did you use ? With a CEL, you should get more than you got..
Old May 25, 2011 | 10:25 PM
dj211's Avatar
dj211
it was a snap-on soule? i did not run codes with this problem but before i did. so maybe tomorrow i will do it again
Old May 26, 2011 | 06:47 AM
IABill's Avatar
IABill
Exclamation
Inspect the wiring harness that runs over the drivers valve cover closley.
After two CPS's I concluded it must be the UVCH started the teardown unbolted the loom fliped it up discovered a very small burn mark in the valve cover. It had two wireds rubbed through where the big plastic covering has slid down slightly.
Hope this helps.......
Old May 26, 2011 | 08:14 PM
dj211's Avatar
dj211
ok thanks a lot! i didn't even think of that. as soon as this Washington weather calms down a bit, i will definitely do that!
fordtruck661
Sep 30, 2013 01:32 PM
texans
26
Sep 2, 2011 05:31 PM
aczar
18
Oct 22, 2009 07:53 AM
dagren99
Feb 25, 2006 08:22 PM
RichPSD
15
Dec 23, 2005 07:32 PM
