Violent Shaking 50-70 mph!!!
Old Aug 21, 2011 | 03:55 PM
Greg B's Avatar
Greg B
A lot of times the death wobble on 99 & newer SD's is caused by the bad wheel bearing design on 4x4's. On the older trucks the wheel bearings are spaced at the exteme outside and extreme inside of the hub, hence the term of inner and outer wheel bearing. The 99 & newer wheel bearings are placed in the center of the hub back to back. The leverage forces that the bearings must withstand results in premature wear of the bearings due to the increased leverage on the bearings. With the bearings installed back to back as they are, they are unable to withstand the leverage of every day driving as long as the old design. Ford uses the new design because it's a little cheaper to install pre-greased sealed bearings back to back then the old design. Dyna Trac makes a conversion kit for SD's that is like the old SD's to the tune of $2000 that cures a lot of the problems with death wobble.
huntin_cowboy
15
Mar 2, 2017 07:47 PM
jmccracken1214
18
Dec 9, 2016 11:19 PM
7283-F250
1983 - 2012 Ranger & B-Series
Jun 5, 2016 02:19 PM
Zorfox
Feb 16, 2012 10:50 AM
Jarhead
13
Mar 20, 2010 08:58 PM
