iac valve
Old May 25, 2011 | 11:57 AM
perryau1996's Avatar
perryau1996
iac valve
I have a 96 with a 5.8. I accidentally broke the black cap off the side of my idle air control valve. It's a little cap on the side that was covering a small hole. It seems to run fine without the cap. Should I plug it, let it ride, or get a new one?
Old May 25, 2011 | 12:10 PM
Duct Tape Racing's Avatar
Duct Tape Racing
You definatel want that fixed and plugged in. If you can fix it, go for it as longas its not gonna fall right apart. If its beyond fix, go get a new one, theyre around $45-$50 at the LPS
Old May 25, 2011 | 12:14 PM
perryau1996
Hey thanks for reply. The sensor is plugged in and seems to be functioning fine. I do need that little hole plugged though correct? Not sure I understand. Thanks
Old May 25, 2011 | 12:58 PM
Duct Tape Racing
What hole are u referring to?
Old May 25, 2011 | 01:50 PM
perryau1996
There is a small round black plastic cap on the side.Actually it's on top when the iac mounted on the engine. The plastic cap broke off and exposed a machined hole. Hey I ended up making my own engine coolant housing out of plumbing fittings to get me by unitl I get to the junk yard. Were you the guy that responded last week about that?
Old May 25, 2011 | 02:47 PM
Duct Tape Racing
Nope not me.
But my philosophy is: if it breaks and you rig it to work, its just fine. But, even though it may work, your gonna want to take it back to origional
LARIAT 85
Nov 16, 2013 11:47 AM
scotty8812
1997 - 2003 F150
Mar 27, 2009 08:55 PM
86stepsideF150
Apr 28, 2008 01:47 AM
dtkkc
Apr 10, 2006 05:42 PM
superstar
Jul 25, 2005 01:16 PM
