Sponsored by: Real Truck
Oil on spark plug threads
Old May 25, 2011 | 10:15 AM
WestCoastTodd's Avatar
WestCoastTodd
The truck: 2000 F250, 5.4L with 250,000km (156,000 miles).
A couple of weeks ago, I had a miss on the #5 cylinder. Pulled the COP, blew out the plug recess with air and got a fair bit of 'something' blasted out. Looked like oil. Plug was totally fouled (it had the miss for a couple of days), and the threads were oily.
Put a new plug in, and it ran fine. A couple of days ago, it's still running fine, but I pulled the plug to check the condition. The tip is clean, nice tan colour, but the threads are covered in oil. I'm reasonably sure it's oil, though the thermostat is right beside #5.
Any ideas where this is coming from? I'd guess a leaking valve cover seal, but that doesn't seem very common.
Thanks,
Todd
Old May 25, 2011 | 10:19 AM
truckerboy's Avatar
truckerboy
since the oil is only on the threads, and not down in the cylinder (tip gives that away), I would venture to guess that the oil is coming down onto the plug. Going from this I would guess based off my experience with pushrod engines that the culprit is your valve cover gasket (this is more common than you think).
Old May 25, 2011 | 02:18 PM
WestCoastTodd
Thanks Trucker. Not a terrible job to switch the gaskets out, I guess. $50 for parts, not bad.
Rwm8082
Feb 28, 2019 09:43 PM
wiley79
15
May 15, 2014 02:19 AM
jayton4
Modular V8 (4.6L, 5.4L)
32
May 6, 2013 07:16 AM
Woodlums
1997 - 2003 F150
Jan 12, 2012 07:30 AM
Thudpucker
1997 - 2003 F150
Dec 29, 2011 07:28 PM
